Mihir Korke
- Joined
- Oct 23, 2019
- Points
- 14
- Model of Z
- 3.0
Does anyone know how to reset the convertible top after I change the battery
No resetting needed, give us some more details and someone may be able to help.Does anyone know how to reset the convertible top after I change the battery
Like the work "Stealership"After disconnecting battery terminals (same as battery replacement) I had the same problem. I took it to the local stealership and for a mere $150 got it fixed. I have since heard that if you connect a trickle charger to the under hood terminals prior to disconnection there will not be a problem. Can't vouch for that.
Unfortunately I have no answer for your dilemma other than the above.
At risk of asking a stupid question, you do press the foot brake then press the roof button? It won't lower if you don't.Everything else works. Door locks, windows functioning normally, radio. Its just the top motor, seems disconnected. I top the top back about 8-10 inches and pressed the down button but no sound. The cylinder is clean and has no leaks. This is an almost new car, only driven 25k miles. The car was last driven 3 weeks ago and the top worked just fine. The battery was old and getting drained so I swapped it for a new one. The car starts better now
