Mainly rear window with a little on the others.
Could be nothing just change in humidity .
If not then you may have some water ingress of sorts.
First place to check for this is under the carpets.
Easiest way to quickly look is
if you look at the picture you the line (left of seat adjustment switch) this is where the front and rear carpets join lift the seat up a little follow the carpet split line till you get under the seat you should be able to put your fingers between the 2 sections and feel if the foam padding under the carpets is dry.
Best picture I could get .
Zeds can hold litres ( and then some ) under the carpets.
When I bought Lynne's zed
The rear roof stitching was destroyed and had been sitting in Glasgow outside for months in our quality weather.
When I got it home started to get it watertight and dry ( roof still has some issues so lives with a cover on) took out the seats , rear speakers pods centre console etc .
Carpets were dry to the touch front and rear bar a damp bit on nearside front footwell.
Let's start with after took carpets out still left about 3 litres of water in the floorpans .
Carpets took a month to completely dry out
it was October so had to dry in house. Squeezed as much water out as I could hung in bath ( when not in use ) on 2 clothes horses water ran to the bottom squeezed out every day once stopped got in front of radiators for a bit.
You just wouldn't believe how much water the foam padding under the carpets can hold .
Anyway long and short of all that is if its dry under the carpets all is well
a dehumidifier will sort it ( or air con fix as said ) but if its wet under there investigation will be required.
Stephen.
