COMPLETED - Site offline for upgrade - 15/08/2013 AM
Hi all,
The forum will be offline for a couple of hours on Thursday morning 15/08/2013 whilst I upgrade the forum software.
The main website will still be working, and you can always drop by https://www.facebook.com/zroadster.org if you get bored! I'll post updates there as and when needed.
Cheers, Gary
Site upgrade has completed and ahead of schedule by 40 minutes!
There may be a few bits of tinkering to do, so please give me a shout if you have any questions or problems.
Thanks for doing the update, good work :)
Cheers Neil!
The upgrade went super smooth as expected. Had a small issue after the upgrade with an add-on which wasn't 100% compatible, but the developer had published a fix before I could even ask him what had happened!
Great stuff Gary :party:
Couple of things I have noticed is that text is in Times Roman format rather than Arial which will upset Terry I know ;)
Also the carbon fibre background has disappeared off the Dark Zorg profile.
Apart from that looks great mate.
Brilliant stuff, but why can I not go back to black and where is the widget for cut and past?
It's Arial on the "Light Zorg" style. I don't use the dark theme, so not sure what it was before!
I can 'tinker' that one back in a second.
Top of page tag has gone as well..........
It is there, but it only seems to work on Internet Explorer and Firefox. I'm chatting with the chap who coded it to see when the Chrome fix will be available...
Looks good Gaz, well done:thankyou:
It was Arial on the Dark theme too, it is just the post text everything else is arial.
Carbon fibre back :drinks:
This probably changed between versions of the theme when it was updated to be XF 1.2 compatible. I'll have another look.
Just noticed 'Logoff' has gone from the menu bar....
Aha - thanks Gary
Fixed.
