Probably interiorView attachment 89342 Quick question to anyone who may know the answer, on the colour label, does the colour at the bottom (schwartz - black- in my case) refer to the primer colour?
Thanks for that. That is intersting to know as I also thought it was the primer colour.No it’s the engine bay and under bonnet/boot lid colour.
YesThanks for the info folks, really interesting and another mystery put to bed.
On another point, am I correct that Z3 bonnets are the same pre and post face-lift?
Yes it doesView attachment 89342 Quick question to anyone who may know the answer, on the colour label, does the colour at the bottom (schwartz - black- in my case) refer to the primer colour?
Are you sure about that @Nodzed ? The lower colour always correlates to the engine bay colour for sure. I have a Topaz Blue car with Topaz Blue engine bay. And another with black engine bay (individual options). The lower colour follows the engine bay on each car.Yes it does
OK yes your are correct its actually called underhood paint but the same paint is used around the waterway in the boot opening and the boot inside etc as far as I can ascertain, why would then put two different types of base paint on? BMW Schwarz Matte code F2380 that is made by duPont is used on cars with top coat codes 303 305 668 (Plus some individuals such as Mora which isn't listed)Are you sure about that @Nodzed ? The lower colour always correlates to the engine bay colour for sure. I have a Topaz Blue car with Topaz Blue engine bay. And another with black engine bay (individual options). The lower colour follows the engine bay on each car.
Would BMW use 2 different colour primers with the same top coat? Perhaps? In which case we are happily both right.
And one other thought, the engine bays are a satin type finish not a hard matt like primer would normally be?
The answer should be on the inside of the front or rear wings which remain in primer to the best of my knowledge. I'll have a look next time I have a pair off, in particular on my 2 Topaz Blue cars.
And of course is also the best colour for a Zed!The top colour is the body colour. The bottom the engine bay etc.
And it’s always in German. A source of some confusion sometimes. Hell Rot is Light/Bright Red not Hell Red
