Coilovers
Lazzzydog
While I was at Demon Tweeks today I enquired about some adjustable coilovers for the Z3M as the current set up is a touch too low for ny taste and I would like some adjustability. According to the info they have you cannot fit coilovers with the standard M wheels without fitting wheel spacers. Can anyone confirm or deny this. Thanks in advance.
Dino D
Kent
2.8 Manual
I believe @Gwyndaf has fitted BC’s to his and @Lee had some (KW I think) on his M so they could answer.
It could vary between brands due differences in design.
5harp3y
Often the case with coilovers as the spring perch sits lower and can interfere with the tyre.
Might only need a 5mm spacer so no drama there
No issue with fitting spacers on the M if you need to, I have 15mm rear and 10mm fronts on the Titan and 15mm all round on the Imola and makes the stance much better me thinks!
Lazzzydog
Thanks for the replies. I will have a chat with you about them an Sunday Nodzed.
