Codes
Dalek
Highworth, Wiltshire
Z3 2.2i Auto
Just had major work done on the engine ( see previous thread) and now have these codes. The Engine light has also come on.
Any ideas?
Not a Vanos expert but I would be looking at the inlet vanos for bad solonoid and or seals then look at fuel trims, usually fuel trims exceeded down to air leaks, not sure if the Vanos fault would have a contribution to fuel trims.
Ianmc
New Forest
Z3 (M44)
I'm no expert in such matters, but have you tried clearing the codes and see if they come back. Could it be part of the "bedding in process"? Seems like a no cost first step.
Dalek
Z3 2.2i Auto
New seals have been fitted on the VANOS. I have reset the codes twice now but they keep coming back. I gave it 200 miles to bed in, so should have by now.
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
To determine if you have a dodgy solenoid swap them over, clear the codes and see if they reappear on the exhaust side. Also check that the shuttle valve behind the solenoid is clean and moves freely in its bore as they can stick.
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
2 things happen here, VANOS and fuel trims. VANOS is timing of valves and does not impact on fuel mixture/trims.
E3/E4 = 227/228 mixture deviations. You will need to check your fuel trims to see if its rich (negative numbers) or lean (positive numbers).
The VANOS advice you have been given is great.
Dalek
Z3 2.2i Auto
Checks carried out today-
Pressurised smoke test on complete inlet system, no leaks detected.
Checked wiring between ecu and vanos solenoid, all ok.
Checked positive and switched earth to vanos solenoid and found ok.
Previously swapped solenoid from inlet to exhaust and triple checked cam timing.
Can anyone think of anything we have missed?
Sajk
On the fuel trims check that the o2 sensor connections are not plugged into the wrong lead. So bank 1 plugged into dme bank 2 and visa versa. Seen that before. Dme keeps trying to trim mixture based on reading from wrong bank.
On vanos no idea.
Eddie Zedder
Z3 2.0
Giving the cam sensors a clean may help.
2.2 & 3.0 Sport
Sorry, but have I missed something but shouldn't the company who did the work on the engine be sorting these problems out?
Dalek
Z3 2.2i Auto
They are working on it.. just using the knowledge on here to make sure I am happy that ghey are not missing anything.
