Code Reader/Scanner/Revving?
Gilly1
Hi there to all. Quick Question, which code reader is recommended for the Z3 1.9 ,also,advice please regarding revving on tickover up to 1.5rpm on idle? Causes please? Thankyou in advance.
Gilly1
Hi there, on the log book it says : first registered 30/01/2001. Is that of help. Thankyou...
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
I would go by it's birthday at the factory as cars can and have sat for many months after dealer delivery before first registration date. It can be found I believe on the drivers door post and contains serial number, date of mfg as well as a few other pieces of info. HTH. JIM
oldcarman
Canadian Zeds
I believe the M44 was produced from 96-2001 as well as the M43 in 2001. As the car was actually certified in 2000 it could very well be an M44 JIM
Z
zedonist
Guest
Typically a 2001 should be an M43 but there are examples of imports being registered late. Rule of thumb though is if it is face lift it is M43
Gilly1
All I found there was tyre pressures. But I did find on the front suspension (under bonnet where it bolts on) BMW.BUILT :OCT.00 So I take it its 2000 Every time I have taken it to the garage they plug in the round connector under the bonnet. But I have found under the steering wheel another connector socket but whether its wired in I don't know. (this one is rectangle) Hope this helps. Thankyou for your help...
There are 2 sockets on the later Z3, but generally you can access everything you need from the round one.
Have they found any codes stored when they scanned it?
Gilly1
not too sure what a face lift is but it is only a single cam motor and only has 1.8 on the boot. thankyou
For reference Gilly it's the mainly the back end which was "face lifted" mid way in the production run. A few components where changed at the same time so it's an easy indicator for spotting which model you have!
Gilly1
they did but could not find a code for this they put the light out but it came back on within a week .as it cost time and money I am going to buy a reader :confused:
Code readers are pretty cheap now so a good thing to keep in the car with you. Where about in the country are you, as there may be someone on here local to you with one who would gladly offer to read them for you!
Gilly1
live in lymington Hampshire but would like to have my own reader
