Clutch replaced...still slipping in 3rd and 4th
Discussion in 'Z3 Roadster & Coupé' started by DivisionPhoto, Sep 13, 2019.
  1. DivisionPhoto
    DivisionPhoto Newbie
    Sep 13, 2019
    I honestly dont know what to do. Just bought my second ever car (Z3 2.8 Widebody) and i cant drive it previous owner just had the clutch done. Apparently the mechanic was able to adjust something in a few minutes to make the clutch feel completely different. I would just like to know what it is and if i need to spend $500 on a clutch.
  2. Lee
    Lee Zorg Guru (V)
    British Zeds #ZedShed M Power
    Mar 26, 2014
    3,339
    4,190
    187
    Model of Z:
    Z3 Roadie 3.0
    Welcome to the forum,
    I've experienced something similar to this and found the clutch line (between solid pipe to slave the rubber bit) had gone soft so every time you press the clutch the pipe just expanded causing you to struggle getting it into gear. It's easy to access under the car drivers side of the gearbox.
    Also check if there’s a clutch stop behind the pedal and make sure the mat is not tucked up behind it.
  3. the Nefyn cat
    the Nefyn cat Zorg Guru (III)
    Oct 19, 2014
    2,306
    762
    138
    Model of Z:
    2.2i Sport
    And sometimes the hose starts disintegrating internally, it'll allow pressure through but won't allow it back. There's also a clutch delay valve fitted to some (at least) of these cars, they can hold pressure in the line and allow the clutch to slip. Happens with brake lines as well, brake goes on but won't come off fully.
    • Agree Agree x 2
  4. t-tony
    t-tony Zorg Expert (II)
    35,187
    16,314
    Model of Z:
    Z4 3.0 Auto
    First thing to check is the clutch flexible hose is still rubber. If it has been changed to stainless steel type forget that as a fault. Secondly, being a suspicious type, did the pervious owner actually have a new clutch fitted? There should be a certain amount of warranty with this job? How long is it since it was fitted and how many miles has it done? There is NO adjustment on the Z3 clutch as far as I'm aware.
    • Agree Agree x 1
