Clutch question for the experts
NigelM
Maldon, Essex
Got an issue with my Z3M Roadster I could do with some help with.
When the clutch is depressed all the way it doesn't seem to be far enough to disengage the clutch. Come to a junction in neutral, depress the clutch and you can't physically engage any gear. Turn the ignition off, engage a gear and restart the engine again with the pedal all the way down and it starts slowly rolling forward with the clutch still depressed.
It's not slipping in any way. It feels like I need to depress the clutch a couple of inches further than it's maximum travel to get it to disengage properly.
Does it sound like a new clutch is required or is it more likely to be pipe/seal/fluid related?
Thanks for your help. Nigel
Sean d
Lincolnshire
I would also say that it sounds like a fluid issue as the clutch is not clearing the pressure plate when pressed.
@t-tony
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
Bleed the slave cylinder as others have advised. Also consider replacing the rubber hose to the slave cylinder. They have been known to start to balloon under pressure when they get old and cause your symptoms.
Alistair Francis
Australian Zeds
1.9L Z3
I didn't replace the clutch hose in this case, now I'm kind of thinking I should have. It does seem hard to undo it from the master cylinder though. I remember looking at the hose and it looked fine.
It does feel noticeably better now. Even in California where it's fairly dry it seems like the DOT-4 fluid absorbed at least some water.
NigelM
Maldon, Essex
Thanks for all the advise. Sounds as if it might well be a fluid/pipe issue. I will have a little dig about this weekend and see what I can find.
NigelM
Maldon, Essex
I drove it today, only about 10 miles so it didn't really get the chance to warm up, but the clutch was absolutely fine. My guess is that the pipe is shot and ballooning when it gets warm, when cold it holds it's form.
Took the hard top off for the first time this morning. Went to raise the soft top and no joy. A bit of digging and found the brake lights were not working. Not a fuse issue so will have a look at the brake switch tomorrow. Raised the hood manually so I could give it a good wash. Clay bar and compound tomorrow, polish and wax on Monday. Should be looking spot on by then.
Thanks so much to this forum and it's members. Through searching through old threads and asking the members I seems to be finding solutions to all the little issues I'm bumping into. A great forum.
Mnbrennan
Aylesbury
BMW M Coupe / 2.8 roadster
Yes, mine was doing this, fine when cold but hard to engage 1st when warm. An Earls braided clutch hose sorted the job!
I'd get it done as soon as possible. It's likely that the clutch is wearing prematurely due to not being fully disengaged
