clutch peddle
Discussion in 'Z3 M Roadster & Coupé' started by swamper, Feb 26, 2012.
  1. swamper
    swamper Zorg Guru (V)
    Supporter M Power
    Dec 4, 2011
    2,593
    813
    181
    Mossley
    Model of Z:
    z3m
    is there anyway to adjust the height of the clutch peddle as its slightly higher than the other 2 peddles?
    just to add there's nothing wrong with the biting point its just the height...ta :ymblushing:
  2. Boysie
    Boysie Zorg Guru (I)
    Supporter British Zeds M Power
    Dec 6, 2011
    1,294
    192
    94
    West Chiltington, West Sussex
    Model of Z:
    M Roadster S50
    Hi
    This was a problem i had when i got the car going from a 1.9 to an ///M
    The dealer said the pedal was higher due to the weight of the clutch,
    more pressure needed on pedal, i didnt know if this was a load of ball
    They changed the clutch pedal complete, they said that Bmw was aware
    and had made an alternative uprated pedal.
    This did help alot, like you, i felt the pedal should roughly level with brake
    I also complained there was no room to rest your foot,
    they commented its a drivers car you dont rest your foot?
    I have since been informed its the width of the ///M gearbox,
    due to lack of foot resting space, i'm ok with it now
  3. swamper
    Supporter M Power
    Dec 4, 2011
    2,593
    813
    181
    Mossley
    Model of Z:
    z3m
    hmm ok so theres no adjustment then....just an unrated peddle...any ideas where one of the said items may be purchased?
    btw cheers Ray ;)
  4. Boysie
    Dec 6, 2011
    1,294
    192
    94
    Model of Z:
    M Roadster S50
    ask at the dealers and say you know somebody who had on replaced
    you never know your luck
  5. swamper
    Supporter M Power
    Dec 4, 2011
    2,593
    813
    181
    Mossley
    Model of Z:
    z3m
    cheers Ray ;)
    edit..just spoke to BMW in stockport and they have never heard of the issue....will have to follow this up
  6. Malcolm E Zed
    Malcolm E Zed Zorg Addict
    Dec 6, 2011
    221
    42
    59
    Pedal
  7. swamper
    Supporter M Power
    Dec 4, 2011
    2,593
    813
    181
    Mossley
    Model of Z:
    z3m
    yep i know... Maurice made me do it....
  8. Boysie
    Dec 6, 2011
    1,294
    192
    94
    Model of Z:
    M Roadster S50
    It was about twelve years ago i had it done
    i bet the bloke was still at school then :D
  9. swamper
    Supporter M Power
    Dec 4, 2011
    2,593
    813
    181
    Mossley
    Model of Z:
    z3m
    we may have found a solution to this little problem ....rather than lower the clutch...im going to raise the brake instead ;)
    we'll see.........its not urgent...may just be a case of getting used to it....but i do find it odd
  10. Boysie
    Dec 6, 2011
    1,294
    192
    94
    Model of Z:
    M Roadster S50
    Swamps
    Going from the accerator to a higher
    brake pedal is that a good idea :-s
  11. swamper
    Supporter M Power
    Dec 4, 2011
    2,593
    813
    181
    Mossley
    Model of Z:
    z3m
    doing the accelerator as well....sorry forgot to add that bit.
    if you remove the rubber cover from the clutch pedal and fit a metal cover.... then fit the metal covers to the other 2 pedal but leave the rubber covers on them it will lower the height of the clutch pedal in relation to the other 2 pedals....(or raise the height of the of the brake and accelerator) depending on how you want to look at it.
    all in all they should line up better ;)
  12. hard top
    hard top Zorg Expert (I)
    Dutch Zeds The M44 Massive
    20,779
    6,060
    213
    Netherlands
    Should have bought an auto......... :-^
  13. swamper
    Supporter M Power
    Dec 4, 2011
    2,593
    813
    181
    Mossley
    Model of Z:
    z3m
    i'd have still found something to alter :))
    anyway....have you ever taken your hard top off to see if you do have a soft top under there :ympray:
  14. hard top
    20,779
    6,060
    213
    Netherlands
    Nope, but I can see it through the rear window of the hard top....... :)
  15. swamper
    Supporter M Power
    Dec 4, 2011
    2,593
    813
    181
    Mossley
    Model of Z:
    z3m
    it might be someones old coat :))
  16. hard top
    20,779
    6,060
    213
    Netherlands
    ^ :)) Like it.
Share This Page
