Davyhoogy
Any tips for changing the clutch cable? Ordered one off ebay a few weeks ago and thought may aswell do it while I'm off for at least 3 weeks.
I'm sure I read a post about rubber clutch hoses possibly causing gear change issues!Its hydraulic
I'd like to know who sent you a clutch cable for a z3Any tips for changing the clutch cable? Ordered one off ebay a few weeks ago and thought may aswell do it while I'm off for at least 3 weeks.
Ah that's just me getting my words wrong ha. I have a braided clutch hose.I'd like to know who sent you a clutch cable for a z3![]()
I like a challenge. If I lose the fluid up my arms then I guess I'll be asking how to top it up the day after hahatips? get someone else to do it, unless you like brake fluid down your arms, in your face, having to bleed the systems afterwards because it all ran out.
Its a horrible job, in the worst of positions...... other than that, give it a go...
Hi Steve, yes the clutch m/cyl. is fed from the brake fluid reservoir via a small hose about half way down the side. It is situated halfway down so that eve n if you lose clutch fluid you can eventually lose clutch operation but still have brakes.This is on my jobs list. I've just read what little there is in Bentley and it says to change your clutch fluid every year! I can't even find the reservoir and don't remember ever seeing it.....
It doesn't run off the brake reservoir by any chance does it?
Ah Thanks Tony.Hi Steve, yes the clutch m/cyl. is fed from the brake fluid reservoir via a small hose about half way down the side. It is situated halfway down so that eve n if you lose clutch fluid you can eventually lose clutch operation but still have brakes.
