#ZedShed Clio Sport 197 Track Car
Nice change in the shed. Project me and a mate have started, getting his Clio built to a track standard then we’ll be playing at the Ring in May. So far she’s fully stripped, has a cage fitted buckets the lot. We’re fully stripping it mechanically and giving everything some love and strengthening.
she don’t look too bad for an 80k French car
subframe to be removed and power flexed
was a very easy job to be fair, only a couple hours
once that was done Dan needed to flex his fabricator skills and start beefing up the subframe, seriously impressed with the quality using our £150 Wolf welding set.
First up knock out the old bushes and remove the bearing sets.
bearing sets to remove
then the magic happens
crazy clean welds
beam is all strengthen and ready for powder coating. Back end of the clio all stripped and waiting for shinny bits.
Impressed that for a French car not a single snapped bolt.
Bazza
Verwood Dorset
Impressed with the welding mate :thumbsup:
  • Agree
Reactions: Lee
Been a huge amount of work done on the Clio. Rear end has been all stripped and powder coated, it’s now ready for reassembly, all the extra bracing looks really good now it’s coated.
So today we focused on the front end. This was way more complex than we thought it was going to be. Fought us all the way. We had to remove the whole shock with assembly because the pinch bolts had both seized. With lots of heat and many hours talking dirty to it we managed to get there.
and after all the unsavoury language
leaves a nice hole in the arch
but we didn’t stop there. In for a penny in for a pound. Obviously it’s French so we found rust
luckily nothing serious
plenty of these items for sale to replace, so we decided to remove the subframe which also meant disconnecting the rack. Gary is more bendy than me so sent him up.
least is nice and relaxing up there
not long later subframe came down complete
right collection of parts now
not much left that can come out, least we can see the oil leaks easily. Looks like sump and drive shaft causing a mess
This is where me n Gary thought it would be rude not to fit a race manifold :)
left an even bigger hole :) we also have everything a good clean up
Leaves Dan having to order lots of goodies
IanA
Oxon
I once drove a Clio Cup at a Jonathan Palmer trackday at Bruntingthorpe. It had a sequential gearbox- absolute hoot.
I've had 2 occasions to strip and rebuild those front suspension units. I won't be looking for a third.;)
After a few weeks of ordering various bits, getting things coated and blasted today we reached the re assembly day. This is the fun bit.
Laid out lots of bits ready to assembled.
Pretty BC coilovers :D
we started at the rear to try balance out the front heaviness. The rear end only took a few hours to assemble.
just some liners and various shields to finish the rear. Front end is a little more complicated.
With Gary practicing his favourite Karma Sutra position would instal the first section of the subframe. He needed to line up the steering rack.
for a french car is surprisingly complex up the front. Having to remove so many old bearings.
So today we all hit the Clio to get her mostly complete. Ended up doing most of Friday too.
The Friday was pressing bushes and getting everything assembled.
These were tough to fit.
but these took it to a whole new level.
one of the rare occasions you can use a press
So for the Saturday I cracked on with the front to start and Hollie jumped on the rear getting the heat shields in along with arch liners.
First on the front was getting the two subframes aligned.
We had a cool visit from a Datsun 120Y today, never seen one of these before.
So I finished the front hub assemblies. They look way to good to fit on a Renault now :D
BC shocks attached
New pinch bolt in.
So now a the front subframes are aligned n torqued I can fit the hub assemblies.
you needed arms everywhere to fit these hubs. Needed to align the drive shaft and fit the bolts from above.
looking all complete from below
crazy complex but a lot of fun to build. Rear now just waiting for brakes
brakes just need some new pistons before they can be fitted.
Such a cool colour.
also can’t wait to fit these team dynamics with track tyres on.
almost time :)
We made it. This was a real fun car to build. So this Saturday begun with checking the torque on everything up front and roughing the tracking by eye.
anti rotation links fitted
started putting the fluids back in.
one of my fav parts next getting the brakes on.
then the callipers, love the colour. Also we fitted the stud kit for ease of changing wheels quicker.
Next we had to fit the brackets that held the abs and brake lines. Took us a bit of head scratching to remember where they went.
Starting to look the part now.
Whilst I was cracking on up front the guys were getting the exhaust and diffuser in.
Scorpion exhaust
real nice fitment.
snug in the diffuser, love all the shinny bits.
front hardware looking the part.
next stop is the 3 hour drive back up north and some wheel alignment.
Jobbie jobbie done done.
The Clio is a beast, managed a couple of laps behind it on the Ring and got some awesome pics from the track photographers.
