clear coat removal
HellRot
ive got some lacquer peel on my front bumper. Id like to ideally remove it and try to relaquer myself. Whats the shopping list to remove the old lacquer. Wet and dry etc? i have a da polisher if i can utilise that as well? Where is the best place to buy some lacquer, rattle can ok or would i need a spray gun etc? Thanks all.
Unlikely you will be able to do that without damaging the paint.
@Sean d Your advice is needed
Ianmc
New Forest
Z3 (M44)
I have a little lacquer peal on my rear spoiler. Told by a body shop that the only solution is a repaint. Would also be interested in any advice. :thumbsup:
137699
Hampshire
M Coupe 3.2 S50
You can't strip lacquer and just re-lacquer - you always have to totally repaint.
Beatleboy
Rub lacquer down with very fine emery paper with plenty of water then repaint .The bodyshop did this on my Jag XK and the results were fine.
JimS
Leeds
Z4 G29 30i
Most bodywork jobs like this are well covered with Youtube how to videos, I would start there.
