Cigerette lighter help
Bazza
Verwood Dorset
Guys advice please how do you remove the Cigerette lighter am trying to hard wire the satnav into the supply but for the life of me I don't seem to be able to remove the lighter:woot:
Mines just a tight push fit Baz. You may have to lever it up with a small flat blade to get it started, best of luck...
The power to the cigarette lighter is on all the time and not controlled by the ignition switch so be careful!
Don't forget the ciggy lighter is always on in the Z3.
I wired our dash cam from the spare switched supply on the radio wiring harness, assuming you have an aftermarket radio. In this way the sat nav will only be powered when the ignition is on.
That's how I wired the dashcam in my Z3 too Brian.
To remove the ciggy body, there are 2 x tabs inside that need to prized inwards with a small screwdriver and then it will pop out, and fitting is the reverse without blowing the fuse when pushing the screw driver in like did and have never replaced it to this day. But being non smoker and have never had anything to plug in has not bothered me.
Tip remove the fuse before starting the job!
Nifty
Ive always been here!! I enjoy reading the posts and chuckle to myself with the comments, you lot are truly nuts sometimes!!:happy:
I'm not the social media type, don't do Facebook or Twitter, bit of an old f**t really.
I like to comment and post on things occasional.
Nifty
