How To Guide Changing Door Handle Rubbers
Low Rider
I thought you might like to see some images of your off side door handle from the inside
On the edge of the door is a small plastic blank. Remove this and using a screwdriver push this bar in as far as it will go.
to this position as below
Using a small screwdriver carefully prise the rubber away from the door as above and away she comes
Replace the rubber and reassemble. once the handle is back in the door using a small hooked item pull the bar towards your self and replace the blank.
Now make your self a brew
Antm72
South Yorkshire
I did this when i brought my car its surprising how much fresher the car looks when they are replaced if they where cracked and split before.
One of the cheapest jobs to do but aesthetically pleasing ...Nice how too but my doors are bigger than yours=))=))
I dod this when i brought my caf its surprising how much fresser the car looks when they are replaced if they where cracked and aplit before.
You drunk @Antm72? :p
Aceman
Moderator
Wakefield
///M Roadster
Great writeup @Low Rider :thumbsup:
Changed the header marker to "How to Guide" and also moved to the knowledgebase so people can find it easier if searching for a solution to this.
Low Rider
LoL
Its not about size its what you do with your doors
2.2 & 3.0 Sport
