Changing bulb behind the 3 dials
Tearoom
Bristol
Hi guys
The 3 dials in centre console below radio do not light up, in fact they have never lit up since I've had the car.
First thing I want to check is the bulb (or bulbs)
What is the best way to get to access this bulb? I'm guessing by pulling out the radio, but do want to do that unless I have to.
Is the bulb obvious and in an accessible location?
Ianmc
New Forest
Z3 (M44)
Radio out, replace bulbs. A bit fiddley but straight forward.:)
Clockwatcher
Lincoln
Z3 2.8 Roadster
I am in the process of doing a DIY LED replacement for my HVAC lighting. Once I have finished, tested and ensured it works I will post how it was done. Each bulb should be under £1.00 if it goes well.
This MAY include the instrument (cluster) panel too. ;)
CW
Clockwatcher
Lincoln
Z3 2.8 Roadster
jonco
Chester
'98 1.9 Auto
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
i go in from the side of the console. bend the plastic back and reach in that way.
I find 'Radio out' method is like putting your hands in a blender.....
I found I could get my hand in quite easily via the radio slot after putting it in the blender, couldn't keep hold of the bulb though :inpain:
Clockwatcher
Lincoln
Z3 2.8 Roadster
Ianmc
New Forest
Z3 (M44)
Helps if you have had training as a gynaecologist.:whistle:
