Changing a rechargeable battery in fob,
Corky999
Hartlepool, Co Durham
E89
Not sure if this helps anyone but my second key was dead and wouldn’t recharge.
I bought a new replacement rechargeable battery bmw button sticker and new fob, cut open old fob to take circuit out, melted solder for battery and pulled off, pushed new battery in holes and bent ends then re soldered, put back in new case and pushed together then stuck bmw sticker on and put the door blade in the new fob. All works perfectly now, cost £12 😎 :coolsteer)
Corky999
E89
Thanks @Corky999 , I have the same problem, can you post the links of of the various parts you used please ?
Can’t work out how to do link so taken pics of what I bought
Corky999
E89
Just use a sharp knife to cut open of one, start with taking blade out and slice through bit that sticks up first then cut round
AleNod
Huddersfield, West Yorkshire
Z4 E89 20i sdrive roadster
Thanks bud, parts ordered.
I'm not a natural bay'er, theres almost too much choice, whichoneissit ?
Tap the 3 dots, tap share, and you can copy the links. Here they are if others are looking . . .
Thanks for your help, top man !
I'm also aware my solder sucker has lost suction decades ago, replacement is £4.62, right, I'll have one of those too . . .
Still better than what BMW quoted me for a replacement key fob . . .
Corky999
E89
If you need any other info/help doing it just message but it’s straight forward 👌🏼
AleNod
Thank you @Corky999 - all sorted now. As easy as you said . . .
Well . . . Splitting apart their flippen key fob was the hardest thing. I think it was glued with superglue (mutters) . . .
But it does come apart, battery does need to be desoldered, but apart from that, nothing complicated . . .
Corky999
E89
Saves a fortune, glad you’re sorted 👌🏼
