Not at all sure you will get that to work without the original instrument cluster being operational as I think the mileage in the cluster is contained in the coding plug on the cluster, the other place its stored may well be the headlight switch pcb and the two compare what each has in them, any mismatch will result in a tamper dot appearing on the odometer display on the instrument cluster.
