Evening all,
I've had my little roadster about 2 months now, and it's been great, but it's obvious that things can be improved.
I dug out the MOT slip and had a look at the advisories:
What I didn't realise is that the rear job was a big one. I've come to learn that in order to change the rear beam bushes, the exhaust and rear axle need to be dropped. This isn't something I can attempt myself, and if I'm paying someone to do it for me, I'd like to make the most of the axle being dropped.
After some time reading on the forum, I've learnt that I definitely want to change the rear beam bushes to Powerflex, and the diff. mounting bush to poly/rubber.
I have a couple of questions to further expand my knowledge of this area:
Thanks in advance for you sterling advice!
Forsh.
Edit: I should also probably mention that this is my daily driver, doing 200-300 miles per week, including motorways.
- Front wishbone rear bushes deteriorated - both sides
- Rear axle carrier bushes (A.K.A rear beam bushes) deteriorated - both sides
- Will new rubber diff. mount bush stop the diff. clunking from 1st to 2nd? Or will I need poly?
- With the rear axle down, would it be advantageous to also replace the rear anti roll bar bushings and the trailing arm bushes? If so, poly or rubber?
- Are there any other areas, other than bushings, that should be replaced with the axle dropped?
- How much should I be looking at in labour costs to drop the rear and replace beam, diff and any other bushings?
Forsh.
