For Sale BREAKING; 1997 Z3 1.9
Andyboy
SHEFFIELD
121,000 miles, Arctic silver with an...er......unusual retrim.
Genuine Rondell 8x17 wheels (ET35)m refurbished with new budget 215/45 tyres. £600.
Most of the panels are knackered. The hood will go again (manual) but the window is shagged.
Non ASC brakes.
It's had new discs and pads and a lot of time spent overhauling the suspension - new track rods, wishbones, coil overs etc.
New exhaust.
Genuine catalytic converter.
Notts NG17.
I've sold a few bits already but plenty left.
Airbag module £20
Bonnet vents £30
Boot latch £10
Calipers £25 each
Coil pack £20
Cylinder head £200
Exhaust manifold £50
Flywheel and clutch £40
Gearbox crossmember £20
Handbrake lever £10
Master cylinder £20
Pedal box £50
Propshaft £40
Rear trailing arms £250
Rear lights £20
Seats £70
Short engine (perfect bores and crank) £150
Steering coupling shaft £20
Undertray £50
Arch liners £40
X brace £50
A few other bits of trim but nothing else. No panels or sills etc.
Hi Andy
Would those seats have the black plastic backs I’m after?
Jane
They’re horrible though. A shitty retrim - I’ll end up taking the motors out and skipping them tbh.
do you have the boot interior trim available? Am looking for the rear panel (up against seats) without a CD changer hump
You will need the side panel too to look tidy as the humped version side panel is cut to fit the hump. Also I believe there are two different versions of the side panel, one for manual soft top and one for a powered soft top with the bulge for the pump. You will need the correct one depending on your soft top.
Airbag module £20
Bonnet vents £30
Boot latch £10
Calipers £25 each
Coil pack £20
Cylinder head £100
Handbrake lever £10
Master cylinder £20
Propshaft £40
Rear trailing arms £125 ea.
Rear lights £20
Undertray £50
Arch liners £40
X brace £50
