Hi all
Might not be a major thing in the total picture. But anyway I'm currently converting my 2.8 into a track car.
And at last trackday I killed my brakes, so I had to move forward the brake upgrade job.
My planned options was:
option 1: upgrade to 330i front brakes (calipers and 325mm discs).
option 2: upgrade to 300mm front discs with carriers and disc. Keeping the OEM caliper.
Everybody is advising me with going for option 1. However upon the weight calculations it revealed that the 330 option would add 7.7kg to my front comparing to option 2 that would only add 1.4kg.
My stand is that bigger doesn't necessary improve actually stopping and brake performance, but does improve the heat handling (cooling) on the brakes. (bigger is not always better )
Regarding cooling I plan to build brake ducts for cold air directly into the disc regardless of chosen option.
So I'm leaning towards option 2, however I'm unsure if the 300mm solution would hold up on track.
So I was wondering if anybody here had been doing some hard tracking with 300mm disc and provide some feedback if this holding up or not.
Really appreciate any feedback!
Sidenote: brake pads is not really part of the topic, I will mostly likely run racing pads.
