Hi . Wondered if anyone on here has fitted a brake switch. I have removed the cowls under the steering and can see it but not sure how to remove it without causing any damage elsewhere. Cheers ......
Pull the red ring out and you will be able to release it from the bracket. First time I did it found it easier to remove the switch and bracket together and then you can see what you are doing.
When you refit just push the red ring back or fit to bracket and press the brake pedal and this the locks it.
