brake refurb kit for the M
swamper
Bacup
M
do they still do them?
its had a new caliper on one side but im thinking of doing the other one....if one sides gone then the other cant be far behind.
anyone ever fitted the refurb kit?
DangerousDave
If you are meaning the caliper seal kits, the part number still exists, but I've been told by various people that no-one is allowed to sell them to the general public incase they fit them wrongly.
Try your local dealer and see if he will sell you a kit.
swamper
Bacup
M
cheers Dave.........anyone want to sell me some seals....down a dark ally away from prying eyes..... alliteratively you could change your name to Hard Top :ymdevil:
Aceman
Moderator
Wakefield
///M Roadster
swamper
Bacup
M
good stuff aceman...your ace :-bd
Aceman
Moderator
Wakefield
///M Roadster
No problem I need to get a set myself as I have a complete spare ///M brake setup which I am going to refurb.
swamper
Bacup
M
i refurbed a set years ago...cant be that much of a job to replace seals like for like
peteslag
Shifnal, Shropshire
Z4M
I've done it on a couple of different cars. If you take your time and keep everything clean it is an easy job. I don't know if that refurb kit comes with grease but if it doesn't, I can recommend "Red Rubber" grease, it is custom made for brake seals, good stuff. :-bd
swamper
Bacup
M
ok Pete i'll keep that in mind ta
swamper
Bacup
M
pete how did you remove the piston?
Aceman
Moderator
Wakefield
///M Roadster
Done mine with a compressed air line on the brake hose, just be careful though as the piston flies out so make sure you do it with the caliper sat on the floor with the piston facing down. ;)
Edit: there is a how to on the Big Red website that shows you the entire process. ;)
swamper
Bacup
M
dont have a compressed air line....any other ideas?
bought a full set of calipers for 100 quid.....so im going to do a refurb on them...they can always sit there as spare ;)
Aceman
Moderator
Wakefield
///M Roadster
Haven't you got a electric or manual tyre pump for that matter which should do the job. The ///M mobility pump should do the job with an air bed adapter on the end.
swamper
Bacup
M
yep...ta ;)
edit....if your going to removed the piston with a compressor be careful....f##k me did that go off :-o
make sure theres a good mile between you and any people...cars... houses or anything that would not benefit from a large hole in it ;)
edit again....piston still in good condition after being retrieved from half way to manchester....no corrosion .....seal inside is good but have wrecked the dust boot .
DangerousDave
Put a block of wood in the gap. The piston will jam against the wood. Then use gradually thinner blocks until you can get the piston out by hand.
swamper
Bacup
M
with a name liker your i would have thought you would have been into high speed flying bits of metal :))
i might have a go at this when some other bits arrive.... @-) ......dont know how to make the link work... @-) ...its late... @-) ..and iv been eating sugar @-) ...again @-)
