Right, then...
I’m sure I know the answer, but I’m not completely sure...regardless, I may be pushing the “there’s no such thing as a stupid question” concept.
Might be facing a brake job, which would include upgrading to braided stainless brake lines, which would necessitate bleeding the brakes. At the same time, I need to do a brake flush. My logic tells me these are largely the same process (pressurize the system with new brake fluid) and uses the same equipment (wrench, brake fluid flush device) but with different desired outcomes: bleeding removes air bubbles and flushing changes the fluid. Am I right to assume this, or am I suffering a logic failure?
Also, with flushing, I’ve seen where they refer to fluid color to determine if you ave all new fluid...how do you do that with the same color fluids?
Thank you!
Thank you!
