For Sale on behalf of a Track Day Colleague, I would not normally post on someone's behalf but this could be a bargain for the right person - but please remember Buyer Beware!!!
Boston Green Z3M CAT D - £8000.00
The car has done 56K miles from new, mileage backed up by MOTs etc. The current owner has had the car for
7 years, the damage was repaired prior to the current owner buying the car the damage for the CAT-D is unknown. The car will come with 12 months MOT.
If you are interested let me know and I'll pass on your details.
MOT History Below: -
MOT history
Date tested 23 June 2016
Pass
Mileage 56,460 miles
MOT test number 1366 3697 4289
Expiry date 22 June 2017
Date tested 2 August 2015
Pass
Mileage 56,156 miles
MOT test number 1073 3431 5298
Expiry date 1 August 2016
Date tested 22 May 2014
Pass
Mileage 54,369 miles
MOT test number 7294 6254 4184
Expiry date 21 May 2015
Advisory notice item(s)
Fail
Mileage 54,632 miles
MOT test number 2396 7563 4416
Reason(s) for failure
Date tested 1 March 2012
Pass
Mileage 53,669 miles
MOT test number 3195 3196 2056
Expiry date 28 February 2013
Date tested 27 February 2012
Fail
MOT test number 2550 6855 2044
Date tested 3 November 2010
Pass
Mileage 52,756 miles
MOT test number 5723 8740 0383
Expiry date 2 November 2011
Date tested 30 October 2009
Pass
Mileage 51,387 miles
MOT test number 8308 8340 9393
Expiry date 29 October 2010
Fail
MOT test number 4111 1330 9490
Pass
Mileage 50,994 miles
MOT test number 4634 0265 8266
Expiry date 7 September 2009
Date tested 31 August 2007
Pass
Mileage 49,519 miles
MOT test number 6738 2364 7251
Expiry date 30 August 2008
Date tested 24 August 2006
Pass
Mileage 47,943 miles
MOT test number 4747 1673 6254
Expiry date 23 August 2007
Date tested 23 August 2006
Fail
MOT test number 1934 6563 6225
MOT history
Pass
Pass
Pass
- Play in steering rack inner joint(s)
Fail
- Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
- Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
- Rear fog lamp not working (1.3.2b)
- Offside Rear Brake hose excessively chafed (3.6.B.4d)
- Exhaust emissions carbon monoxide content at idle excessive (7.3.D.4)
- Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.3)
- Exhaust emissions hydrocarbon content after 2nd fast idle excessive (7.3.D.3)
Pass
- surface corrosion on floors/brake pipes
- Fuel pipe/s corroded
- Oil leak
- front brake discs scored and pitted
Fail
- Nearside Stop lamp not working (1.2.1b)
- Offside Stop lamp not working (1.2.1b)
- Nearside Rear Tyre not fitted in accordance with side wall instructions (4.1.D.1f)
- Oil leak
Pass
- Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
- Centre Brake pipe slightly corroded (3.6.B.2c)
- Offside Front Tyre worn close to the legal limit (4.1.E.1)
- Child seat fitted not allowing full inspection of adult belt
Pass
Fail
- Nearside Rear Direction indicator incorrect colour (1.4.A.2f)
- Offside Rear Direction indicator incorrect colour (1.4.A.2f)
- Nearside Side repeater incorrect colour (1.4.A.2f)
- Offside Side repeater incorrect colour (1.4.A.2f)
- Nearside Rear Shock absorber insecure (2.7.2b)
- Offside Front Direction indicator slightly discoloured (1.4.A.2f)
Pass
Pass
Pass
Fail
- Nearside Front Brake pipe excessively corroded (3.6.B.2c)
- Offside Front Brake pipe slightly corroded (3.6.B.2c)
