- Joined
- Apr 22, 2019
- Points
- 85
So another minor issue has popped up this evening. I sent my lad out to put some bits into the boot and he used the key to unlock the boot, which is probably the first time the key has been used in 17years. The key then got a bit stuck and the car alarm went off.
The boot opened though, and we reset the car alarm.
After a bit of a wiggle the key finally came out, but now it won't lock, neither on the central locking, nor using the key.
The key simply won't rotate and the central locking doesn't lock the boot either. If we lock the car with the boot lid closed, it simply opens again and teh alarm goes off.
When using the key to try and lock the boot, it as absolutely solid and will not rotate.
Any ideas?
Any ideas?
