Boot break light seal.....
Discussion in 'Z3 Roadster & Coupé' started by FRANKIE, Dec 6, 2014.
  1. FRANKIE
    FRANKIE Zorg Guru (V)
    American Zeds The M44 Massive
    Sep 2, 2013
    5,330
    3,420
    187
    Model of Z:
    I've noticed that when I open the boot, the opposite side of the boot (inside top) is wet. Is this a bad break light seal? Is it hard to change? Is the dealership the only place to get one. Frankie
  2. hard top
    hard top Zorg Expert (I)
    Dutch Zeds The M44 Massive
    20,779
    6,062
    213
    Netherlands
    • Like Like x 1
  3. Barry Gadd
    Barry Gadd Zorg Addict
    British Zeds The M44 Massive
    Mar 29, 2014
    118
    64
    46
    Woking Surrey
    Model of Z:
    Z3 1.9L
    Hi Frankie,
    I had the same problem.Some of the plug in bulbs had failed so I replaced those and then teased out the light unit.It's easy to clean up the gasket and the hole it fits in to,.then applied a smear of silicone sealant. It sealed nicely (checked this by pouring water over the unit with the boot closed) No leakage since.
    • Like Like x 3
  4. FRANKIE
    Sep 2, 2013
    5,330
    3,420
    187
    Model of Z:
    I'll give it a try. If I understand what you're saying, you're using the same gasket, but added some silicone to it?
    • Agree Agree x 1
  5. Barry Gadd
    Mar 29, 2014
    118
    64
    46
    Woking Surrey
    Model of Z:
    Z3 1.9L
    Hi Frankie,
    Yes... I cleaned the gasket and that part of the boot lid it seals against and then applied a generous spread of sealant. I wiped off any that squeezed through and left the sealant to set (dry). It worked well.
    I wish all the jobs I've done on the Z were that simple !!!
    Good luck
    • Like Like x 2
    • Thank You! Thank You! x 1
