Having spent some time looking at the incredibly expensive induction kits from the US of A, I started looking in to a self build solution. This isn't a discussion over the merits of an induction kit, just how I'm going to try and assemble parts to make my own.
The initial issue with the Si air box is that the MAF housing is built in to the lid of the box. Ditching the air box means there is nowhere to plug the MAF, which is going to be relatively problematic.
Quite by accident I stumbled over something on eBay while searching for something else. A custom made MAF housing for the N51/N52 engine, but for a different part numbered MAF. Had a chat with the US seller, and took a punt. It arrived today, and the MAF is a perfect fit!
Small initial issue that it's the same dimension as the existing pipework. Pic below shows them next to each other. As it stands the pipe on the left will need to be removed. Should be able to easily work around it!
There are now lots of things to think through at this point trying to find the best place to locate it. I will need to lose some of the existing pipework and air box, then source a cone filter, extra hoses, connectors etc.
Been looking at these for around £30, but not sure on quality. High Performance ‘MAF Safe’ Twin layer dry foam. I will probably end up buying a conventional cone filter as well to see what difference there is (if any).
Then should this all connect together nicely, I'll be working on a heat shield. Will update the thread as I progress...
