BMW Z3 Spark plugs seized
Discussion in 'Z3 & Z3 M Roadster & Coupé Knowledgebase' started by RichardKings, Jul 14, 2014.
  1. RichardKings
    RichardKings Regular Member
    Jun 30, 2014
    11
    3
    14
    The spark plugs on my 2 ltr. are seized any ideas how to free them without having to take the head off would be appreciated.
  2. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,208
    9,348
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Hi Richard,
    Is there any movement in the spark plugs at all, and have you tried squirting some penetrating fluid on them yet?
  3. RichardKings
    Jun 30, 2014
    11
    3
    14
    Hi Gaz ,
    There's about a 1/4 turn before they seem to lock up put penetrating fluid on them & at the time there was no change. The engineer I use is about an hour away from me so we have decided to leave it for a while & they will come out with the engine as hot as it will get after an hours drive, think that might work?
  4. GazHyde
    Dec 2, 2011
    15,208
    9,348
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    The other suggestion was to try and move them when the engine is hot, so hopefully that will help!
  5. RichardKings
    Jun 30, 2014
    11
    3
    14
    Thanks I'll let you know but I will wait until after my holiday.
    Richard
    • Like Like x 1
  6. Cooper
    Cooper Zorg Guru (IV)
    Supporter Australian Zeds
    Apr 17, 2014
    1,173
    762
    157
    Hobart Tasmania Australia
    Model of Z:
    3.0i 2001
    I have heard of people mixing diesel fuel with engine oil at a ratio of 1:1 and then applying a small amount and let it sit. This [apparently] frees up the most stubborn bolts and items.
  7. t-tony
    t-tony Zorg Expert (I)
    31,726
    14,965
    220
    Model of Z:
    Z4 3.0 Auto
    When you do it Richard, use a long a socket bar as you've got with as short an extension as you get away with and try to keep the socket and extension in line with the plug to avoid any side load which will snap the porcelain. You do not want any of that getting into the cylinders.
  8. RichardKings
    Jun 30, 2014
    11
    3
    14
    Thanks both I will try it all & keep everything crossed.
    Richard
  9. phil.a
    phil.a Zorg Legend
    Jul 18, 2014
    336
    334
    77
    redditch
    Model of Z:
    z4
    coke cola good perpetrator leave it over night then work on tighten then loose tighten then loose, small turns at a time keep doing it
  10. RichardKings
    Jun 30, 2014
    11
    3
    14
  11. oldcarman
    oldcarman Zorg Guru (V)
    Supporter Canadian Zeds The M44 Massive
    Feb 11, 2014
    9,986
    3,617
    177
    Pine Falls Manitoba can.
    Model of Z:
    If it works for this what's it do inside our systems??
  12. phil.a
    phil.a Zorg Legend
    Jul 18, 2014
    336
    334
    77
    redditch
    Model of Z:
    z4
    the same thats why your teeth fall out:eek:
    • Agree Agree x 2
    • Funny Funny x 2
