I have just had the electric seats from my Z3 2.8 back from recovering. Before fitting the seats back to the car I have removed the ball screws and renewed the bushes and at the same time noticed the motor drive on 1 rail stalling.
I removed the unit as pictured and open the case, inside there is a alloy screw gear and a white plastic gear, the white plastic gear has a large flat spot which is causing the unit to stall.
Does anyone know where I can get a replacement without having to get a salvage seat base which may have the same issue?
Thanks.
Thanks.
