- Joined
- Apr 1, 2016
- Points
- 253
- Location
- Maybole , South Ayrshire
- Model of Z
- Z3 Individual Dakar / Orinoco Individual
Still has a type of clutch switch or bypass whether manual or auto
Stephen
Stephen
Thanks Stephen, but as mine's a M54 fly-by-wire do I still need this? The diagram above is for earlier no-fly-by-wire vehicles. I guess if I can't make it work any other way I could bridge pins 23/24 of the ECU anyway?Didn't realise an auto right then you will need to check it has the clutch bridging switch in place.
View attachment 251887View attachment 251889
Stephen.
I fitted Cruise Control to my 2002, M54 fly by wire, 2.2 a few years ago. The clutch switch was already fitted and wired up. All I did was fit the column switch and the controller. All works fine, including the cruise disengaginng when the clutch pedal is depressed.Thanks Stephen, but as mine's a M54 fly-by-wire do I still need this? The diagram above is for earlier no-fly-by-wire vehicles. I guess if I can't make it work any other way I could bridge pins 23/24 of the ECU anyway?
Absolutely Ade, That's all I did. Just needed brake light bulbs replacing to get it to work but if your bulbs are ok, it shouldn't be a problemJust about to install the same on my M54 3.0 manual... Am I correct that the above doesn't apply to mine and its just a matter of plugging in the interface and stalk switch?
