Guys, can you remove them without the keys, I was going to make some wire ones if they will work, cheers
Thanks pal, just had a go but didn't know that I had to push inwards, I'll try againYou can use bits of wire (coat hanger) to push the clips inwards Sean, you'll just need something to pull the unit forwards with. Finger in cassette slot maybe.
Sorry Sean, I assumed you knew that you needed pullers on your unit, my bad.Thanks pal, just had a go but didn't know that I had to push inwards, I'll try again
My eyes are not that good mate but I did manage to see that they are screws after a while of trying to get wire in thereI have a business head unit and to remove it i just have to unscrew 2 torx screws behing the flaps which slackens the unit off and it pulls free have never needed to insert anything ?
