SOLD BM multi-system Scanner C310+
GDavis
Bristol
Z3 2.8 facelift. Z3 3.0i
Hi Joss
Apologies do you mean this plugs into the drivers side footwell port ?
Are there any disadvantages to only having access through that port ?
Gordon
Hi Joss
Gordon
Gordon the obd plug under steering column only gives limited access.
You need a 16pin to 20 pin obd adapter plenty on ebay £7 or so allow to plug into the obd port under bonnet for full module access.
The 310+ will also work on all newer bmw and mini models.
Stephen.
GDavis
Bristol
Thanks Stevo
Looks like that ones gone.
Gotta keep looking i guess.
Which scanner would you recomend Stevo...budget is not endless.
