Bleed nipple on a brake caliper
Discussion in 'Z3 Roadster & Coupé' started by Philpatton, Sep 10, 2019.
  1. Philpatton
    Philpatton Dedicated Member
    Apr 22, 2019
    100
    58
    39
    Evening all,
    I’m just finishing up the refurb of 2 rear Bmw brake callipers I got of a fellow forum member and I want to make sure I don’t snap the bleed nipple when I come to install the callipers. I’ve been spraying a little wd40 onto the caliper where the nipple is to allow it to penetrate the threads since Sunday and I’ve been tapping the area with a hammer to try and break any corrosion that may be binding up the nipple.
    I there anything else I can do to make sure that when I finally try and open the nipple, it doesn’t shear?
  2. Althulas
    Althulas Zorg Guru (III)
    Jun 14, 2014
    2,478
    941
    142
    Milton, Banbury
    Model of Z:
    M Roadster
    Could try a bit of heat around the bleed nipple area and then spray some more wd40 but if they are well rotted in may need to resort to drilling them out. Mine were well and truly stuck managed to unloosen the rears but my front bleed nipples just crumbled. Best of luck.
  3. mrscalex
    mrscalex Zorg Guru (IV)
    Supporter British Zeds 3rd Party Trader
    Jun 10, 2016
    3,711
    1,817
    150
    I've found they round off before they snap.
    I just have a replacement caliper on standby now. Too much hassle drilling out.
  4. t-tony
    t-tony Zorg Expert (II)
    35,187
    16,314
    Model of Z:
    Z4 3.0 Auto
    Use a 1/4" drive 6 point socket not a spanner. Try to tightening direction before loosening.
    #4 t-tony, Sep 11, 2019
    • Agree Agree x 2
  5. Sean d
    Sean d Zorg Guru (V)
    Sep 29, 2015
    8,508
    8,457
    190
    Lincolnshire
    Model of Z:
    Cracking off of the bleed nipple is the first thing I do when refurbing calipers because if one snaps the caliper is only good for the scrap bin, just done these. I like using freeze spray as it contracts the steel nipple and can help break a bond. 20190830_120001.jpg
    • Like Like x 1
    • Agree Agree x 1
  6. Philpatton
    Apr 22, 2019
    100
    58
    39
    Well, after days of spraying with wd-40, I got home today, took my ring spanner’s and took the nipples out. They were very tight, but came out anyway. I ended up using another spanner to lever on the 7mm spanner to get enough force on it.
    I tried my 7mm socket, but is wasn’t deep enough and only captured 1/2 of the nut.
    Next job is paint, but they will not be anything as smart as Seans. They look proper smart!
    P
    • Funny Funny x 1
  7. motco
    motco Zorg Addict
    Dec 6, 2011
    192
    61
    59
    Chilterns
    Model of Z:
    Z3 2.2i Sport
    I have to change my brake fluid - you make my blood run cold with the possible snags! I have bled brakes through the pipe union before now because I was worried about the nipple failing.
