#ZedShed Bills Black Beauty Z3M (Gearbox & Subframe)
Next in the shed is a stunner, a very rarely seen black Z3M. @BillH We’re sure we’ve seen this car before the plate looks familiar. Anyway we started off doing the seat bushes at the same time we did Boisie’s and found they had been done before but the blocks were a loose fit.
Here she is.
She arrived in style with a very hot smelly Front calliper well and truely stuck on.
Also some interesting bits, like a flat bottom steering wheel. Strangely the first Z3M I’ve seen with a manual roof.
With the seat bushes done we rolled her in ready for Saturdays tear down.
She didn’t disappoint, she came apart relatively easy I don’t think @Mazza would agree we left him fighting the exhaust for an hour up front.
Not to much rust at all, just surface.
Near side
And the normal shot beam bushes. Sat rubbing on the plate.
this time we spent around 2 hours getting the car apart as the front exhaust section flanges didn’t want to come apart.
can confirm torn beam bushes.
They shouldn’t be trying to polish the plate =))
Let the strip down for powder coating begin.
and the other
we had one casualty. One of the wheel bearings protested being removed.
Under side looking all dusty.
Now the back was stripped we had a look round the rest of the car. Looks like a mechanic forgot to fit bump stops and dust covers to the front shocks, this is actually an MOT failure.
All the hardware up front has been replaced recently so no need for me to do too much. I’ll need to remove the shocks and sort the mistake and rebuild both front callipers.
Both callipers, one has an incorrectly fitted seal so no surprise it’s now stuck.
plenty to keep me busy the coming weeks. Diff needs some love
old beam bushes removed.
one hell of a pile of parts for powder coating.
Lots of ordering to do tonight. :)
BillH
My black beauty! Never heard it called that before 😊 so, a few issues already which i thought id had sorted. The BMW specialist I took it to wasn't perhaps the specialist I thought. At least I'm confident it's now in safe and experienced hands and am already fascinated with all the work to get that improved driving experience. Thanks guys - I'll be bringing up the rear shocks when they arrive along with the biscuits - or just folding stuff for the brekky!
Hi Dino I assume this is my car in the shed but.....- I must be a bit thick cos I don't get your post - what you putting where??
Dino has a real soft spot for the rear M wheel.
BillH
Yeah, they are a bit sexy 😂 glad I didn't change them for 18"ers
Today was a good day, shame we had no powder coated bits. It was a more relaxed chatty type of day, even @mwpe came down and offered his wisdom.
The last big job was removing the gearbox for indent pin replacement. Bill made the call late in the day to replace the clutch and flywheel so for now the gearbox is staying out. Gearbox gave us a little fight coming out, nothing we couldn’t handle. The ZF gearbox found in all 2.8/3.0/M’s
With @Mazza standing by taking notes we started doing the simple indents gears 1-4. First pin bits removed
New bush going in
Now sporting the new orange bush
followed by new spring
and finally the cap. (No longer stocked by BMW now sourcing these caps elsewhere)
once those 3 were done. It was the tough ones. Reverse and 5th you need to break out the old liner.
once 5th and reverse are done you should have a full house.
while we were inside the guys outside begun stripping down the front callipers and cleaning up the diff. Clear to see with the piston on the right rust under the dust cover line, this in turn means it will grab in the bore.
This is what happens with a badly fitted dust cover.
Rebuild kit ready and waiting.
But first they need painting :) (first coat)
Then a photo of the diff receiving a clean up.
Next we pulled the flywheel and clutch assembly. Not in bad condition for 70k. Few heat marks nothing big.
Pressure plate
clutch disc itself just starting to crack.
Also worth noting @Mazza fitted your set of tank straps today, he did say it’s now double the price…. His analogy was “you don’t see Bill Gates coming round to install office for you” =))
We compared the new front M discs to the pattern part discs fitted, no comparison really.
Pattern part (non floating)
BMW disc (floating)
So plenty of progress made today. Old shocks also removed, not much we can do now till the powder coated bits arrive.
Mazza
Bognor Regis
Another fun day in the Shed.....with Lee, Gaz, Trev, Paul and Mike
And learned a load more.......it’s like being back at school .....only more enjoyable!!! =))
Nice to actually fit a set of straps on an ///M. ( but dont panic Bill, thats all I was allowed to do and Lee will check my work :thumbsup:)
BillH
It's taken 2 beers and 2 re-reads to appreciate everything you guys have done to put right some shoddy past work carried out on poor old 'black beauty'! I'm not sure I supplied enough biscuits for 6 people, but I'll add to the bacon butty fund next time I'm up there. Almost sounds like a proper worksite - 1 supervisor, 1 foreman, 3 workers and an apprentice 😆😆😆 Everything is looking great and apologies for the late call on the clutch - hope that hasn't created any problems for you and I hope I have 'supplied and fitted by Mazza' signed on the tank straps 😂 looking forward to the next installment - and a big thanks to all who've been involved 🍻🍻🍻
Only a little update. Still waiting on the powder coaters to catch up, he was saying now everyone’s back at work it’s gone silly. He’s promised everything by the weekend.
Spent a few hours cleaning brakes and painting a few bits.
Second coat on the front callipers and painted the first coat on the rears.
I also removed the old diff bush ready for the new one to be fitted.
now ready
we also took delivery of the new clutch & flywheel.
still plenty of bits to fit.
this also might be the last full build for a little while, I start my new job in a couple of weeks. If I do any more they won’t be at this pace because I can’t do this many hours during the week :)
BillH
All coming together nicely and even the weather looks like it's improving 🌞 I feel very lucky to be the last big rebuild before you start your new job - think I'll buy a lottery ticket for this weekend! Thanks Lee, Trev and all your team 👍👍👍
Very productive day today, trying to get ahead ready for Saturday.
First up we fitted the new clutch kit and flywheel
also new release bearing in the gearbox.
we also noticed some really perished rubber hoses in hard to reach places so Bill can add these to the list for future work. Throttle body number 6 vacuum line is split
we also pulled the front shocks and fitted the new bump stops with lowering springs.
other side.
Finally we got the powder coating back, it’s taken them two weeks.
beam
More bits.
I also collected the freshly painted wheels.
full house
next we started populating the metal work with new bushes. The guys cracked on and fitted the new diff bush.
Also subframe getting its Bilstein bushes fitted
Then to get us ahead for tomorrow we started assembling the arms. New bearing fitted
next up the backing plate and hub
new handbrake hardware
then disc back on and handbrake adjusted.
this sets us up for tomorrow so we can chat more :D
Bit late with the Saturday update, Bill was here most of the day so got to see first hand the chaos. The morning was building Mazza’s subframe and arms and Pm was reassembling Bill’s M. She’s around 90% complete just waiting on the return of grit blasted brake carriers.
we started assembling around midday, back end back together and torqued. All looking very shinny now.
shortly followed by shocks and lowering springs. Prop and exhaust followed after.
Beam bushes now sat at the correct height and being fully supported by the bush.
shot from the rear looking in.
just needs brakes now :D
