Battery Tender
Discussion in 'Z3 Roadster & Coupé' started by SYMZ3, Jul 14, 2019 at 9:46 AM.
  1. SYMZ3
    SYMZ3 Regular Member
    May 11, 2019
    24
    8
    13
    Hi Folks,
    I have a battery tender which I used to keep my bike’s battery in good shape over the winter. Our 2.8 isn’t going to get a lot of use through the winter.
    I am assuming this batt tender will be okay to look after the Zed’s battery? Do I use the jump start ports under the bonnet or connect directly to the batt as I did on my bike?
    Appreciate any advice and thanks in anticipation.
    Chris
  2. colb
    colb Zorg Guru (II)
    Nov 25, 2012
    606
    352
    108
    Model of Z:
    1.8
    Probably best to connect direct to battery terminals, no loss of current as it would if connected to the under bonnet terminals, the longer the cable run to the battery will see a drop of current so I am led to believe. Keep my bike on a tender without any problems, not used on the Zed as I start her up and run her over the winter whilst she is laid up.
    • Like Like x 1
  3. SYMZ3
    May 11, 2019
    24
    8
    13
    Thanks Colb
  4. Fender2004
    Fender2004 Zorg Addict
    Sep 23, 2014
    122
    62
    49
    I use a Ctek battery conditioner on my Z over the winter, and I’ve never had a problem. Battery now coming up to 9 years old.
  5. t-tony
    t-tony Zorg Expert (I)
    32,113
    15,114
    220
    Model of Z:
    Z4 3.0 Auto
    I have a similar item to the C-tek. I connect direct to the battery and close the boot lid catch with a screwdriver (so it's sensed as locked) then gently lower the lid onto the cable.
    • Like Like x 1
  6. SYMZ3
    May 11, 2019
    24
    8
    13
    Thanks Tony, I thought as much. Appreciate the expert advice
