Badge
ljbmwz3
Lymm
Dakar 2.0
Hi just wondering how you get the badge out of the front side grill as ones a bit flaky ,have got another and note the 2 retaining struts do u just push on em ? thought I would ask u folks before I brake em :)
Rudyrov
Phoenix, AZ
2.8 L Roadster
I did mine about six months ago, what I did was remove the side grills and then push the badges out from the inside.
I put pressure on the dowl's that are on the badges because my badges had a lot of double sided weather stripping holding the badge to the grill's.
Once I had made room under the badges I used plastic prying tools and a glue dissolver called "OFF" to help loosen the weather stripping.
Then you mount the new badges and put the assembly back on the car "Voila" !!
Oddly Godly
dunstable
z3 2.8
I changed all my badges for black and white ones a few months ago. From what I remember I stuck the new ones over the top of the originals. Being a bit sunken it doesn't show. I may of had to chop a couple of lugs of the back of the badge. As the grill's are chrome is was worried about scratching them if I tried to remove the original badges. I think the proper way would be as described above.
Front badge is held on just with the 2 pins go into 2 plastic grommets fitted into bonnet ( which can be replaced, ) you just need to be careful when removing it.
