Hi Guys
Just brought a Z3, 01 2.2i
It's just coming up to 90.000 has full service history, I've just had an oil service and changed the air filter and spark plugs using NGK BKR6EQUP. Since doing so the car has developed a backfire but mainly in the lower gears when letting off the accelerator. Apart from the this the car seems to running fine and not missing at all.
I've torqued according to info online, Could someone suggest what this should actually be? As I'm going to check again later or if there are any other thoughts?
Thanks
Thanks
