SOLD Automotech Portable Tilting Lift
Bought this in May and used it once.
It's no longer required as I have purchased a different type of ramp.
Great bit of kit, on full height the car will tilt to the point you can sit underneath the rear or front to work, also locks level if required.
Normal raise / lower is manual with the supplied handle ( I would not choose to do this unless you are built like Rambo)
Cost new delivered £410
Also available
Powerful SDS drill to power up / down the ramp, this did not come with the ramp but purchased separately.
(NB a normal mains or battery drill will not lift a car (I tried quite a few)
Cost New £90
Lift £330
Lift & Drill £400
Collection only OR arrange your own courier
PM ONLY Please - if you are interested
The photo of the black Z4 shows the lift at approx quarter height
gookah
Shropshire
2.8 Z3
I can vouch for these on a Z:
Remember though that you need enough room at the side to slide it under, a good 3ft6in, or more.
wont go under from front or rear.
in action...
can be locked in horizontal and all wheels removed, or tilted for loads of room at ether end.
In the video, that was not at full height,...you can still see a lot more silver shaft to go on the bottom tube
ps I don't have Parkinsons, it's a wobbly joint.... (not one of my joints either) :D
in action...
Thanks Pete, I had these photos but thought it was a bit cheeky using them :whistle: :whistle:
Brian H
Killin
E36/7 3.0i - E85 Z4///M
I can vouch for these too, great lift.
