The drive select indicator on my `98 1.9 has developed a fault. Drive select works Ok but indicator is not moving from P position.
Have lifted the plate and the slider works Ok and indicates positions but the connection to the actual handle shutters has failed - presume this is a pin or plastic lug connection.
I am trying to find part number - probably under my nose in realoem but I can't see it.
This is the underside view
Anybody breaking an Auto?
