Auto gearbox fault?
bronty
Ashton in Makerfield
2.8 auto pre facelift
I have a Z3 2.8 1997 automatic
When I drive it from cold it drives great good gear change and smooth.
When I stop the car and switch off the engine then restart it drives off but on th 3rd gear change it jumps (feels like under the seat) then I get the engine management light on.It dose not go into limp mode just jump on high end gear change it feels like it jumps into gear.
If I switch the car let it go cold it runs fine again.
I have been told it could be a switch on the gearbox but unfortunately these switches are now obsolete
I am waiting for an adapter for obd so I am not sure what the fault code is.
I will take the car to a garage but not sure on a local garage that would be good with an old car.
Has any one had a similar problem?
First thing to do is get the codes read as warning lights coming on there will be a code stored that will hopefully steer you in the right direction.
Stephen.
bronty
A quick update
I took the car to a automatic transmission specialist and he hooked is diagnostic to the car at a charge of £75
He did not look to assure and suggested a software update at £350 then if that fialed to change the Mechtronic unit
So before spending I bought the creator C310+ and an adaptor
It gave me two faults
08 air mass flow señor on the engine
99 CAN DME load signal
I have ordered a new mass flow señor and will see if that clears both faults
When I cleared the faults the car drives great again no jumping into gear
Yeah, some specialist then eh?
bear2020
Norwich
Z3 3.0 & Z4 2.5
I had an issue with my 3.0 but it was changing down. From 3rd to 2nd and then 2nd to 1st. It felt like someone stomping on the brakes. I renewed the auto fluid, changed the filter, changed diff fluid. Still did it. I then added some Dr Tranny Fluid https://www.britpart.com/all-parts/da6809 and instantly made a difference. Its not gone totally but probably because I knew it was there but to anyone else they do not know. Might be worth a try as I thought it was sensors and all sorts and at £15 thought it was worth a go
bronty
The New MAF arrived today I fitted it very simple 10 min job and it worked
No engine management light No gear jumping and drives smooth
Just need the sun to come out now
So now you know not to take it to that garage ever again. Code reader and this Forum are your best friends going forward.
bronty
It is not the first time I have fallen foul of the garages
I had the dreaded critical gear box failure on a Range Rover after nearly 4k spent at experts. it turned out to be a Hydraulic torque limiter on the haldex pump found a bloke on the internet who fixed it for £180.
