Auto Box Fluid
Jon Woody
Anyone got any views on "Lifetime auto fluid". My 2.8 Z3 has covered 74k now & I'm not happy that the oil has never been changed.
I've got a quote for £400 to change the oil & filters but understand that a substantial amount of the old fluid remains in the torque converter.
Anyone had theirs changed??
abh29
North Wales
Z3 2.2 Sports
My son had trouble with the Auto box in his CooperS and took it to specialist [Good reputation and only work on Auto box,s] box needed a rebuild at 80,000 miles and they considered it was entirely due to the oil loosing its properties. Surprising how much work they did for main dealers on cars only 3/5 years old and over 75,000 miles Interestingly in some countrys BMW include gearbox oil changes in the service at around 80,000 miles. Afraid I consider "never needs changing" as meaning until the part needs changing instead of oil.
Jon Woody
My son had trouble with the Auto box in his CooperS and took it to specialist [Good reputation and only work on Auto box,s] box needed a rebuild at 80,000 miles and they considered it was entirely due to the oil loosing its properties. Surprising how much work they did for main dealers on cars only 3/5 years old Interestingly in some countrys BMW include gearbox oil changes in the service at around 80,000 miles. Afraid I consider "never needs changing" as meaning until the part needs changing instead of oil.
I agree but I'm not happy to part with £400 if a substantial amount of the old oil remains in the torque converter. I'll have to see if i can find a local auto specialist to see if there's a way to change all or most of the old oil
abh29
North Wales
Z3 2.2 Sports
What part of the country are you based in , someone hear will know of a suitable specialist in your part of the country. Mine of info available on the site
Some oil will remain in the converter, unless it is removed that is unavoidable. I changed the Auto box oil on my Z3 including the filter in the gearbox. The oil was quite expensive and required around 7 later. IIRC. Parts and oil were probably £125 (ish - it's a good few years ago now). I did this at around 70,000 miles
I did a "How to" write up which is on here.
Jon Woody
Thanks I'll see if I can find it
abh29
North Wales
Z3 2.2 Sports
Not my part of the country ,but try a quick call to Opie Oils , they are only in Redruth so I am sure he will know the area.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
I had the autobox oil changed on my old merc about 5yrs ago and the bill was £250ish. I haven't changed the zeds yet
Jon Woody
I've found two companies who use a flushing machine & claim to replace 98% of the old fluid. Flushes through pipes etc as well so sounds like a good option. Had a quote for £306 including replacing filters so I think it's a no brainer!!....
