Found At this rate i will be building a new car!
Kenhayes247
Meissendorf, Germany
So, i have a Z3 build year 2001 with a 1.9L engine. Should this model have the following fitted?
Fuel filter cover
Engine under tray/splash shield
Gearbox under tray/splash shield
If so, I am missing all three. Is the engine and gearbox tray/s separate or are they joined together?
Many thanks
Ken
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
Not sure on the filter cover, the undertrays were fitted to some but not all models. I seem to remember that they weren't fitted to later 1.9's but I could be wrong!
If you put the last seven digits of your chassis number into RealOEM then you will see if they were applicable for your model.
Brian4
Near Grantham
Z3 3.0i Auto
Fuel filter cover
Many thanks
Ken
realoem pages for 2001 1.9 only the parts listed are fitted even though there are images of all the bits.
https://www.realoem.com/bmw/enUS/showparts?id=CM12-EUR-07-2001-Z3-BMW-Z3_19&diagId=51_2370
https://www.realoem.com/bmw/enUS/showparts?id=CM12-EUR-07-2001-Z3-BMW-Z3_19&diagId=51_2358
fuel filter cover yes
no other covers apart from one at the very front between bumper and radiator.
Kenhayes247
Thank you for that, i will give that a go
Kenhayes247
Looks like I am missing the one between the bumper and radiator - thank you for the link
Mazza
Bognor Regis
I have a 1998 1.9 and there are two undershields on mine.
The front one... bumper to Radiator
And at the back of this one there is another that covers the sump, gearbox and fuel filter .
This is the only picture of the rear one I have. There is also a sump nut access panel on the rear one.
handsomejackuk
Australian Zeds
t
same here on my 1.9 front and back covers present and the cover for ther fuel filter
Brian4
Near Grantham
Z3 3.0i Auto
That is correct for a 1998 car but the 2001 cars didn't have the cover under the engine and gearbox according to realoem parts list. I am sure one could be fitted but doesn't look as if was originally supplied with one. My 3.0i has only got one from bumper to radiator.
Kenhayes247
Thank you all for the replies. Mazza the pictures were really useful. I definitely don't have the bumper to Radiator nor the fuel filter shield but shouldn't be to difficult to source. I did look at the RealOEM and my later car wasn't fitted with the gearbox cover.
Eddie Zedder
Z3 2.0
Before you source an airduct, check that you have the side panels intact (4&5 in pic) as you need these to bolt to and they're not so easy to install.
On the plus side these plastics are relatively cheap new from BMW.
Kenhayes247
Thanks Eddie, i checked whether the side panels were fitted and they are. There is also signs of where the air duct was fitted at some point as well. Just need to get the duct and fuel filter cover.
Eddie Zedder
Z3 2.0
Happy to help Ken, just make sure the bolt holes are good, the plastic gets very brittle with age. Mine disintegrated at speed 4yrs ago and I never bothered replacing it.
My 99 1.9 ( facelift) has fuel filter cover and radiator to bumper one
No under engine cover fitted
I think I'm right in saying that the piece between the front bumper and the radiator bottom, if missing, can affect the cooling of the engine?
Eddie Zedder
Z3 2.0
Doesn't seem to affect mine Tony. Mind you I still have my temporary one in place.
