Anyone know where....
MartinJ
Hi all, out in Z land. anyone know where I can get the following done. I have removed the rear end.( See Pesky Bolt thread... ) Now at the beginning of the process to put it all back together. I need to have the rear beam axle and diff bushes removed so I can clean , de -rust and coat / paint and refit. I also need trailing arm bearings removed and new part fitted. The parts are all off the car.
Does anyone know of anyone in the Bristol or North Somerset area who can do the above ?
Cheers
Fender2004
Durham
You could buy a bearing/bushing removal tool and do it yourself. Plus you will have to tool if you need it in the future.
MartinJ
Thanks for the advice. I have sorted the bush issue. Now need to know where is best place to buy bearing kits for trailing arms (Realoem no: 334111243580) regards turnaround of order ,price and quality?
