Anyone done a BMW Z3 V8 conversion?
wca
I have mildy tweaked the exterior of my 2.8 Z3 and am now looking for a bit more power. There are various suggestions on the internet about changing the inlet manifold and such like but I thought dropping a big V8 might be a nice starting point.
I have seen an article about some New Zealand kid dropping an M5 V10 into his Z3M Coupe but I may have access to a cheap Lexus V8 with box that could do the trick. They are reliable blocks that can be boosted up easily, another NZ looney has had 2,700hp out of one apparently. I am only after 3-400BHP as I have a tuned Merc for fast work.
Any links, advice or thoughts welcome.
Pic of the exterior modes below
Brian H
Killin
E36/7 3.0i - E85 Z4///M
V8s have certainly been done before, I can think of a couple in the last 4 or 5 years. It is not a job for the faint-hearted.
wca
Designing and commissioning the rebody wasn't without its moments. I am happy with the result though.
I hope to repeat this with the drive train too.
Any links? Anyone used a Lexus lump rather than an LS1?
I need to mate it to an auto box due to injured leg and I understand the Lexus unit can handle the tourque
Not heard of a Lexus engine being used before, nor anyone converting to an automatic for that matter. Tends to be something used from the wider BMW range which usually takes less messing with.
A quick google for auto conversions doesn't really draw up anything. @deano1712 has put an LS motor in his Z3, but that's a manual.
Brian H
Killin
I am sure you had you challenges, I should have maybe said that it is not a plug and play project. I have not heard of a Lexus lump being put in to a Z, who know you could be the first ;). Good luck with the project.
V8 build by Snatch
V8 build by Deano1712
Z
zedonist
Guest
V8's are so last year, I recently put a merlin engine in mine just for a hoot, boy did that pop and burble on the over run. Anyway put it back to the M44,and wow what a transformation, such a lovely drive.
wca
Look at the picture at the top. Would a V10 fit?
I would love to do it.
I ran a V12 Merc for a while and it was creamy
wca
My bonnet is low at the front compared to stock Z3 hoods
There are some videos on You tube of Z3 V8. I think one was from a Camaro. Watched it recently.
