Any thoughts on these?....
Coffee331
Maynooth
2.0 Roadster (2000)
miller1098
Carno,Welsh Wales
M
Personally and I'm all for individuality,I don't think it does anything for the car,have you seen @t-tony frontrunning lights they're not bad ,especially at Christmas lol
Brian H
Killin
E36/7 3.0i - E85 Z4///M
as the rear of the z is a good bit lower and smaller than most other cars out there, I was half thinking of fitting one of these
http://www.3rdbrakeflasher.com/brak...er-module-with-brake-force-monitor-p-183.html
I can pretend it's for safety reasons but it's not really just think it looks cool :)
Any thoughts, would it suit the car or just look a bit too much?
From the description the module would only activate when it detects higher G-force that normal and assuming that you only fit it to the third brake light circuit this will then flash when you have to brake hard.
If you did fit it, it would be a subtle mod so don't worry what we all think, we would only know if we were behind you and you slammed on the anchors :)
I see this type of thing on a lot of newer cars and it tells you that the car in front is having to brake really hard so back off!
Also it would be undetectable on an M.O.T. Test as the car lights are tested with the car stationary, or even in the brake rollers as they only turn at walking pace.
swappy
Nottingham
2.0 Roadster
I like it :) the idea that it only flashes under medium to hard braking is good, might prevent some other dosey driver rear ending you. Most of the other i've seen only working with led's and flash as soon as you touch the brake pedal but they only cost a couple of quid off ebay. This might be a bit expensive after shipping/import duty otherwise I'd definatley buy one.:thumbsup:
Think I might order one...I'm still in the honeymoon phase so she deserves a treat to help us bond [emoji23]
Man that never stops.lol.
