Just had another look on OEM and yes its greyed out so maybe you don't have a post cat sensor, best get under there and check visually to confirm. If there isn't one then maybe thats why we were seeing a flat line on the monitor.
Pre cat one seemed to be ranging ok when viewed in INPA, didnt look slow.
Be careful cleaning the Maf, I tried that and it killed it completly, new one sorted my problem.
Bad Mafs don't always set codes in my experience and if its not performing as it should it will have an effect on the fueling.
Disconnect it and see if the default it will go to leans the mixture. Might be worth pulling the spark plugs to have a look at the colour they are, should be a bit black if running too rich.
