Meyle rear shock mounts worked a treat all Zorted now, also today i fixed the drivers rocking
chair with Gazhydes little repair blocks and manages to fix the up/down motor and linkage
so a test drive revealed No Rocking,In/Out Up/Down movement fine, and no more rattles when hood up.
As for an update on the Antenna, i have decided not to buy a new antenna base as it would
have to come from America and also the bracket is missing along with one of the grommets
and instead i am going to fit an aftermarket antenna that has a removable whip. I will let you know
how it goes when all fitted and i'll take some pics.
Regards
Dave Beard
