Are there any other forum members that have swapped a Getrag 6 Speed in there M Roadster/Coupe?
I am very happy with my conversion.
Phase 1 - Replaced the rear main seal, pilot bearing, UUC lightweight flywheel and E34 M5 clutch, UUC custom Short shifter, carrier, DSSR, stainless clutch hose, new BMW 6 speed weighted shift knob, 325i slave cylinder, new giubo, shortened and balanced drive shaft, new center bearing. Installed Getrag 6 speed trans.
I noticed it could use new motor mounts, so I ordered some as well as a SuperSprint header and I plan to install those next month.
Phase 2 - rebuilding diff with 3.64 gears, new bearings and seals, 3 new clutch discs and steels in the LSD.
cut the car up and finally properly fix the defect all of our cars have with the lack of a proper rear sub frame.
