I've searched and read through plenty of these types of thread looking for clues on my own situation but no luck as yet, so I am throwing this out to the Z community in anticipation of a spark of genius.
The car.
An early '98 Z3 1.9 M44
Air-con, Alarm, Power hood.
Boshe DME ver M5.2 with EWS 2
Sat in a garage for 5 years.
The problem.
Cranks but does not start.
Battery recharged and holds its charge. Also used a booster pack in case but cranks like a trooper.
Fuses and relays all checked (3 times) All good. (1 fuse blown but tracked to boot loom and repaired)
No spark at plugs - Power goes to coil pack but I think no signal from DME to activate.
Fuel pump does not prime when ignition is switched on. Fuel pump works by running a direct supply. Wiring good to relay but no signal from DME to activate.
Have a copy of INPA connected and running from the 20 pin under the bonnet. Only errors are from disconnecting the battery supply to recharge.
Crank and cam sensors have been checked and are showing correct resistance.
Connections between EWS/DME ok
Wiring between DME and fuel relay ok
All earth points checked.
From my research so far (I think) the EWS is doing it's job (recognising the key and allowing the starter to operate).
I assume that either the EWS & DME are not talking or just that the DME may be faulty.
Does any one know of a reliable company that I can send the DME for checking? Most require the whole car but I'm trying to do this on a budget.
I am now scratching my head and could do with a few pointers. Any one know where I should be looking next?
Are there any more systems that may stop the DME from operating the fuel/spark?
I have loads of other work (service, brake lines, rocker gasket, rear screen, MOT) to do on the car but wont start these until the car does.
Thanks for reading.
Steve
The car.
The problem.
Thanks for reading.
Steve
